주요 콘텐츠로 건너뛰기
RCA RCT6303W87 Speaker Replacement
필요한 것
  1. RCA RCT6303W87 Speaker Replacement, Battery: 1 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement, Battery: 1 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Speaker Replacement: 2 단계, 이미지 1/1
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. RCA RCT6303W87 Speaker Replacement: 3 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 3 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 3 단계, 이미지 3/3
    • Remove cover completely.
  4. RCA RCT6303W87 Speaker Replacement: 4 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 4 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 4 단계, 이미지 3/3
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Speaker Replacement: 5 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 5 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 5 단계, 이미지 3/3
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Speaker Replacement: 6 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 6 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 6 단계, 이미지 3/3
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Speaker Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Speaker Replacement: 8 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 8 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 8 단계, 이미지 3/3
    • Carefully peel off the battery.
  9. RCA RCT6303W87 Speaker Replacement, Speaker: 9 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement, Speaker: 9 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement, Speaker: 9 단계, 이미지 3/3
    • Disconnect the speaker cord from the motherboard.
  10. RCA RCT6303W87 Speaker Replacement: 10 단계, 이미지 1/3 RCA RCT6303W87 Speaker Replacement: 10 단계, 이미지 2/3 RCA RCT6303W87 Speaker Replacement: 10 단계, 이미지 3/3
    • Use the plastic spudger to slide the speaker out.
결론
Akitaka Hashimoto
회원 가입일: 03/27/18
525 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G2, Harley Spring 2018 IUPUI, Team S3-G2, Harley Spring 2018 회원
IUPUI-HARLEY-S18S3G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 442
