소개
If you notice your battery life deteriorate, or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
- Back Cover
- Battery
Use this guide to replace the battery of your RCA RCT6378W2.
Remove your memory card before beginning this procedure to protect it from any damage.
필요한 것
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide.
다른 12명이 해당 안내서를 완성하였습니다.
7 Comments
Links on ordering replacement batteries
Great step by step instructions not for novices!
i liked good job
where do i order the battery for RCT6378W2
RCT6378W2 where can i get a replacement battery
