소개
If you notice your battery life deteriorate, or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
- Back Cover
- Battery
Use this guide to replace the battery of your RCA RCT6378W2.
Remove your memory card before beginning this procedure to protect it from any damage.
필요한 것
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide.
Most important step not mentioned is to REMOVE memory card. Just lost 10-15 years of non-replaceable memories due to memory card damage.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 7개
Links on ordering replacement batteries
Great step by step instructions not for novices!
i liked good job
where do i order the battery for RCT6378W2
RCT6378W2 where can i get a replacement battery
Remove memory card
James Reason - 답글
