소개
Upon using this guide, the user will be able to evaluate and repair problems occurring as a result of a stuck volume button. The guide outlines all tools and steps needed to perform the replacement.
필요한 것
Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
Separate the front and back covers using one of the plastic opening tools.
Dislodge the power button from the upper right corner of the tablet's back cover using the tweezers
Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
다른 한 분이 해당 안내서를 완성하였습니다.
