소개
Upon using this guide, the user will be able to evaluate and repair problems occurring as a result of a stuck volume button. The guide outlines all tools and steps needed to perform the replacement.
  1. Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
    • Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
  2. Separate the front and back covers using one of the plastic opening tools.
    • Separate the front and back covers using one of the plastic opening tools.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Dislodge the volume button from the upper right corner of the tablet's back cover using the tweezers
    • Dislodge the volume button from the upper right corner of the tablet's back cover using the tweezers
  5. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
    • Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Wills
회원 가입일: 2015년 01월 29일
444 평판
안내서 4개 작성하였습니다
Clemson, Team 14-4, Shirley Spring 2015 Clemson, Team 14-4, Shirley Spring 2015 회원
CLEM-SHIRLEY-S15S14G4
6 회원들
안내서 15개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 163
