주요 콘텐츠로 건너뛰기
RCA RCT6773W22 Battery Replacement
필요한 것
  1. RCA RCT6773W22 Battery Replacement, Battery: 1 단계, 이미지 1/2 RCA RCT6773W22 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: 2 단계, 이미지 1/3 RCA RCT6773W22 Battery Replacement: 2 단계, 이미지 2/3 RCA RCT6773W22 Battery Replacement: 2 단계, 이미지 3/3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
    My tablet gets hot to were it smells melts and burns me
    KACHINA Price - 답글
    Yikes! It sounds like your battery might be overheating. Try opening up the tablet and check the condition of the battery. It will probably need to be replaced.
    Kelsea Weber - 답글
  3. RCA RCT6773W22 Battery Replacement: 3 단계, 이미지 1/3 RCA RCT6773W22 Battery Replacement: 3 단계, 이미지 2/3 RCA RCT6773W22 Battery Replacement: 3 단계, 이미지 3/3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelsea Weber
회원 가입일: 11/12/15
19,867 평판
안내서 32개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 3,830
