주요 콘텐츠로 건너뛰기
RCA RP3715A Motherboard Replacement
필요한 것
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: 1 단계, 이미지 1/1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 2 단계, 이미지 1/3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 2 단계, 이미지 2/3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: 2 단계, 이미지 3/3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  3. RCA RP3715A Motherboard Replacement: 3 단계, 이미지 1/2 RCA RP3715A Motherboard Replacement: 3 단계, 이미지 2/2
    • Using flathead screwdriver undo the release tabs.
  4. RCA RP3715A Motherboard Replacement: 4 단계, 이미지 1/3 RCA RP3715A Motherboard Replacement: 4 단계, 이미지 2/3 RCA RP3715A Motherboard Replacement: 4 단계, 이미지 3/3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  5. RCA RP3715A Motherboard Replacement: 5 단계, 이미지 1/2 RCA RP3715A Motherboard Replacement: 5 단계, 이미지 2/2
    • Pry open both tabs to remove the topside of the clock.
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: 7 단계, 이미지 1/1
    • Remove the two 10 mm Phillip's #1 screws.
  8. RCA RP3715A Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the gray panel from the frame.
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: 9 단계, 이미지 1/3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: 9 단계, 이미지 2/3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: 9 단계, 이미지 3/3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
  10. RCA RP3715A Motherboard Replacement, Motherboard: 10 단계, 이미지 1/2 RCA RP3715A Motherboard Replacement, Motherboard: 10 단계, 이미지 2/2
    • asd
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: 11 단계, 이미지 1/1
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: 12 단계, 이미지 1/1
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
  13. RCA RP3715A Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the transformer by pulling back the release tab shown.
  14. RCA RP3715A Motherboard Replacement: 14 단계, 이미지 1/1
    • Pull the battery terminal through the whole shown.
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: 15 단계, 이미지 1/1
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 16 단계, 이미지 1/3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 16 단계, 이미지 2/3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: 16 단계, 이미지 3/3
    • Remove the motherboard from the frame using the illustration shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander Trowell
회원 가입일: 09/22/14
222 평판
안내서 2개 작성하였습니다
USF Tampa, Team 10-5, Brown Fall 2014 USF Tampa, Team 10-5, Brown Fall 2014 회원
USFT-BROWN-F14S10G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 557
