주요 콘텐츠로 건너뛰기
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
필요한 것
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 1/3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 2/3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 3/3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 2 단계, 이미지 1/3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 2 단계, 이미지 2/3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 2 단계, 이미지 3/3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 3 단계, 이미지 1/2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: 3 단계, 이미지 2/2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
결론
Allison Baudoin
회원 가입일: 12/05/11
401 평판
안내서 4개 작성하였습니다
James Madison, Team 2-1, Allen Fall 2011 James Madison, Team 2-1, Allen Fall 2011 회원
JMU-ALLEN-F11S2G1
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,272
