주요 콘텐츠로 건너뛰기
RCA ViSYS 25424RE1 Keypad Replacement
필요한 것
  1. RCA ViSYS 25424RE1 Keypad Replacement, Base: 1 단계, 이미지 1/3 RCA ViSYS 25424RE1 Keypad Replacement, Base: 1 단계, 이미지 2/3 RCA ViSYS 25424RE1 Keypad Replacement, Base: 1 단계, 이미지 3/3
    • Remove the eight 11mm screws found on the bottom side of the base with a Phillips #00 screwdriver.
  2. RCA ViSYS 25424RE1 Keypad Replacement: 2 단계, 이미지 1/3 RCA ViSYS 25424RE1 Keypad Replacement: 2 단계, 이미지 2/3 RCA ViSYS 25424RE1 Keypad Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to separate the back and front pieces.
    • Gently remove the back cover, because the wires are connected to each piece.
  3. RCA ViSYS 25424RE1 Keypad Replacement: 3 단계, 이미지 1/3 RCA ViSYS 25424RE1 Keypad Replacement: 3 단계, 이미지 2/3 RCA ViSYS 25424RE1 Keypad Replacement: 3 단계, 이미지 3/3
    • Unclip the wires that connect the front piece to the circuit board on the back piece.
  4. RCA ViSYS 25424RE1 Keypad Replacement, Keypad: 4 단계, 이미지 1/2 RCA ViSYS 25424RE1 Keypad Replacement, Keypad: 4 단계, 이미지 2/2
    • Remove the nine 11mm screws from the board using a Phillips #00 screwdriver, in order to expose the keyboard pressure sensors.
  5. RCA ViSYS 25424RE1 Keypad Replacement: 5 단계, 이미지 1/3 RCA ViSYS 25424RE1 Keypad Replacement: 5 단계, 이미지 2/3 RCA ViSYS 25424RE1 Keypad Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the rubber keypad.
    • Use a pair of tweezers to lift the number pad from both ends at the same time.
결론
Munija Ramin
회원 가입일: 02/18/15
143 평판
안내서 1개 작성함
Penn State, Team 1-17, Kaschak Winter 2015 Penn State, Team 1-17, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S1G17
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 286
