주요 콘텐츠로 건너뛰기
RCA Visys 25212 Handset Battery Replacement
필요한 것
  1. RCA Visys 25212 Handset Battery Replacement, Handset Battery: 1 단계, 이미지 1/1
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Handset Battery Replacement: 2 단계, 이미지 1/2 RCA Visys 25212 Handset Battery Replacement: 2 단계, 이미지 2/2
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
결론
To reassemble your device, follow these instructions in reverse order. Make sure the battery connector is fully seated in the handset before replacing the back cover.
Sandy South
회원 가입일: 01/26/15
431 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 5-3, Prince Winter 2015 Pasco Hernando, Team 5-3, Prince Winter 2015 회원
PHSC-PRINCE-W15S5G3
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 434
