주요 콘텐츠로 건너뛰기
RCX 1.0 Batteries Replacement
  1. RCX 1.0 Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Place the RCX on a flat surface.
  2. RCX 1.0 Batteries Replacement: 2 단계, 이미지 1/1
    • Flip the RCX over so its black IR window is facing away from you.
  3. RCX 1.0 Batteries Replacement: 3 단계, 이미지 1/1
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
결론
To reassemble your device, follow these instructions in reverse order. The orientation of the gray battery cover doesn't matter.
다른 3명이 해당 안내서를 완성하였습니다.
notexactly
회원 가입일: 05/18/10
375 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 2,659
