주요 콘텐츠로 건너뛰기
REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement
필요한 것
  1. REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Remove 4 screws at the back of the control hub: 1 단계, 이미지 1개 중 1개
    • There are 4 00 Phillips screws located at the back of the Control Hub, two are located behind a sticker which you will have to poke through or peel off.
  2. REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Pry open Control Hub Case: 2 단계, 이미지 3개 중 1개 REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Pry open Control Hub Case: 2 단계, 이미지 3개 중 2개 REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Pry open Control Hub Case: 2 단계, 이미지 3개 중 3개
    • After unscrewing the 4 00 Phillips screws you will need to pry open the plastic housing of the case to expose the circuit board.
  3. REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Isolating the Board: 3 단계, 이미지 1개 중 1개
    • After prying off the plastic case, you should be able to freely remove the board along with the piece of plastic it rests on. Remove the board from this plastic exposing the electronics.
  4. REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Flip The Board Over locate XT30 Through Hole Connectors: 4 단계, 이미지 1개 중 1개
    • After isolating the board flip the board over and locate the XT30 Through Hole Connectors
  5. REV Robotics Control Hub XT30 Connecter (Male/Female) Replacement, Desolder and resolder: 5 단계, 이미지 1개 중 1개
    • Simply desolder the XT30 you desire to replace, then using either a wick or desoldering iron clean the area. After this resolder a new XT30 connector ensuring it is oriented correctly
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Rhys Panopio
회원 가입일: 11/07/23
121 평판
안내서 1개를 작성함
2가이드 댓글
IMPORTANT 🚨 Do not use XT30 Connectors from rev or any other standard parts supplier. Most suppliers sell the “XT30U-M”. The connector that comes with the board is the XT30UPB-M”. This is an important distinction and the standard plug will not work in this board.
Tiger Li - 답글
@tiger_li , thank you for sharing the warning.
We are a wiki and if you'd like, you can make an edit directly to this guide to warn fixers who might be attempting this repair.
Kris Rodriguez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 41
전체 시간: 811
