주요 콘텐츠로 건너뛰기
RICATECH-RTT22 Turntable Belt Replacement
필요한 것
  1. RICATECH-RTT22 Turntable Belt Replacement, Belt: 1 단계, 이미지 3개 중 1개 RICATECH-RTT22 Turntable Belt Replacement, Belt: 1 단계, 이미지 3개 중 2개 RICATECH-RTT22 Turntable Belt Replacement, Belt: 1 단계, 이미지 3개 중 3개
    • Remove the arm holder by moving the needle to the side and lifting up.
    • Remove the rubber pad by lifting it up.
  2. RICATECH-RTT22 Turntable Belt Replacement: 2 단계, 이미지 3개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 2 단계, 이미지 3개 중 2개 RICATECH-RTT22 Turntable Belt Replacement: 2 단계, 이미지 3개 중 3개
    • Flip over the record player. There should be screws (10mm phillips head) on the back.
    • Use your phillips head screwdriver to remove each screw (keep them in a safe place for later).
  3. RICATECH-RTT22 Turntable Belt Replacement: 3 단계, 이미지 3개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 3 단계, 이미지 3개 중 2개 RICATECH-RTT22 Turntable Belt Replacement: 3 단계, 이미지 3개 중 3개
    • There will be three wires connecting the top to the bottom. Disconnect them carefully.
    • Put the back component of the record player to the side.
  4. RICATECH-RTT22 Turntable Belt Replacement: 4 단계, 이미지 3개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 4 단계, 이미지 3개 중 2개 RICATECH-RTT22 Turntable Belt Replacement: 4 단계, 이미지 3개 중 3개
    • Use your phillips head screwdriver to remove the three screws (8mm phillips head) holding the motor in place.
    • Keep in mind that there is some pressure on the motor, since the belt holds together the motor and turntable.
  5. RICATECH-RTT22 Turntable Belt Replacement: 5 단계, 이미지 2개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 5 단계, 이미지 2개 중 2개
    • Unbolt (6mm bolt) the turntable from the housing using your wrench.
    • Since the turntable is designed to rotate, make sure the other side of the pin is kept from rotating while unbolting.
  6. RICATECH-RTT22 Turntable Belt Replacement: 6 단계, 이미지 2개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully removed the rubber band from around the motor and extract the turntable from the device.
  7. RICATECH-RTT22 Turntable Belt Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the damaged belt. Place the new belt around the turntable.
  8. RICATECH-RTT22 Turntable Belt Replacement: 8 단계, 이미지 2개 중 1개 RICATECH-RTT22 Turntable Belt Replacement: 8 단계, 이미지 2개 중 2개
    • Follow the instructions backwards to reassemble the record player.
결승점
작성자
1다른 기여자 명과 함께
Celeste Greenbaum
회원 가입일: 03/08/17
101 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 910
