주요 콘텐츠로 건너뛰기
RIDGID BELT SANDER R2740 Timing Belt Replacement
필요한 것
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: 1 단계, 이미지 1/1
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: 2 단계, 이미지 1/1
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: 3 단계, 이미지 1/1
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
brian bither
회원 가입일: 01/10/19
232 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 26
전체 시간: 950
