소개
If your RIDGID R2740 Belt Sander stops when applied to the work piece, is low on power, or making a squealing sound, the timing belt may be bad. This guide will show how to replace the timing belt in the RIDGID R2740 Belt Sander. You will need a Flathead screwdriver and a T20 screwdriver.
필요한 것
Orientate the sander so that the timing belt housing is facing you.
Remove the 19mm T20 screw from the center of the timing belt housing.
다른 한 분이 해당 안내서를 완성하였습니다.
