주요 콘텐츠로 건너뛰기
RIDGID Belt Sander R2740 Power Cord Replacement
필요한 것
  1. RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 Power Cord Replacement: 2 단계, 이미지 1/2 RIDGID Belt Sander R2740 Power Cord Replacement: 2 단계, 이미지 2/2
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 Power Cord Replacement: 3 단계, 이미지 1/3 RIDGID Belt Sander R2740 Power Cord Replacement: 3 단계, 이미지 2/3 RIDGID Belt Sander R2740 Power Cord Replacement: 3 단계, 이미지 3/3
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Cameron Smith
회원 가입일: 01/10/19
303 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 12
전체 시간: 647
