주요 콘텐츠로 건너뛰기
RIDGID Belt Sander R2740 Tension Lever Spring Replacement
필요한 것
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: 1 단계, 이미지 1/1
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: 2 단계, 이미지 1/3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: 2 단계, 이미지 2/3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: 2 단계, 이미지 3/3
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: 3 단계, 이미지 1/2 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: 3 단계, 이미지 2/2
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bryan Garcia Gomez
회원 가입일: 01/13/19
201 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 14
30일 전: 28
전체 시간: 1,704
