주요 콘텐츠로 건너뛰기
RIDGID R2740 Ball Bearing Replacement
필요한 것
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: 1 단계, 이미지 1/2 RIDGID R2740 Ball Bearing Replacement, Ball Bearing: 1 단계, 이미지 2/2
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID R2740 Ball Bearing Replacement: 2 단계, 이미지 1/1
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
  3. RIDGID R2740 Ball Bearing Replacement: 3 단계, 이미지 1/2 RIDGID R2740 Ball Bearing Replacement: 3 단계, 이미지 2/2
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Smith
회원 가입일: 01/10/19
303 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 1,014
