주요 콘텐츠로 건너뛰기
RIDGID R2740 Motherboard Replacement
필요한 것
  1. RIDGID R2740 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Unplug your device before proceeding..
  2. RIDGID R2740 Motherboard Replacement: 2 단계, 이미지 1/1
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
  3. RIDGID R2740 Motherboard Replacement: 3 단계, 이미지 1/2 RIDGID R2740 Motherboard Replacement: 3 단계, 이미지 2/2
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
  4. RIDGID R2740 Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 589
