주요 콘텐츠로 건너뛰기
RIDGID R2740 Motor Replacement
필요한 것
  1. RIDGID R2740 Motor Replacement, Motor: 1 단계, 이미지 1/1
    • Orient the Ridgid Sander to where the Air Guard logo is facing upwards.
    • Unscrew the outlined screw in the figure with a Torx TR10 screw bit.
    • Remove the guard that is protecting the tread-line.
  2. RIDGID R2740 Motor Replacement: 2 단계, 이미지 1/3 RIDGID R2740 Motor Replacement: 2 단계, 이미지 2/3 RIDGID R2740 Motor Replacement: 2 단계, 이미지 3/3
    • See attached diagram.
    • The guard below the wheels should be able to lift up out of place.
    • Remove the timing belt from the pulleys.
    • Unscrew the three screws with a Phillips #1 screwdriver.
    • Remove the large pulley after removing the screw.
    • Using the Torx TR10 Bit, unscrew the 10 screws which hold the external casing in place.
  3. RIDGID R2740 Motor Replacement: 3 단계, 이미지 1/1
    • Remove the plastic housing by lifting it up from the device.
  4. RIDGID R2740 Motor Replacement: 4 단계, 이미지 1/1
    • Flip the Ridgid Sander so that the Ridgid logo faces upwards.
    • The Ridgid Logo should be facing upwards.
  5. RIDGID R2740 Motor Replacement: 5 단계, 이미지 1/3 RIDGID R2740 Motor Replacement: 5 단계, 이미지 2/3 RIDGID R2740 Motor Replacement: 5 단계, 이미지 3/3
    • Remove the brush caps from either side using a flathead screwdriver (See attached diagram).
    • Remove the plastic cover with the Ridgid logo.
    • Remove the brush assembly (See attached diagram).
  6. RIDGID R2740 Motor Replacement: 6 단계, 이미지 1/2 RIDGID R2740 Motor Replacement: 6 단계, 이미지 2/2
    • Now orient the Rigid Sander to the other side that shows the exposed motor.
    • The motor will be able to lift up out of place.
결론
Errett Gary Bainum
회원 가입일: 10/02/19
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 640
