주요 콘텐츠로 건너뛰기
RIDGID R32104 Motor Bearings Replacement
필요한 것
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: 1 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement, Motor Brush: 1 단계, 이미지 2/2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: 2 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement: 2 단계, 이미지 2/2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: 3 단계, 이미지 1/1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 4 단계, 이미지 1/3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 4 단계, 이미지 2/3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: 4 단계, 이미지 3/3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: 5 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement: 5 단계, 이미지 2/2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: 6 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement: 6 단계, 이미지 2/2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: 7 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement: 7 단계, 이미지 2/2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: 8 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: 8 단계, 이미지 2/2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: 9 단계, 이미지 1/2 RIDGID R32104 Motor Bearings Replacement, Gear Box: 9 단계, 이미지 2/2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 10 단계, 이미지 1/3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 10 단계, 이미지 2/3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: 10 단계, 이미지 3/3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: 11 단계, 이미지 1/1
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lucas Pimentel
회원 가입일: 04/02/19
1,010 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 회원
UMASSD-JULIE-S19S5G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 546
