주요 콘텐츠로 건너뛰기
RIDGID R32104 Saw Blade Replacement
필요한 것
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: 1 단계, 이미지 1/1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: 2 단계, 이미지 1/2 RIDGID R32104 Saw Blade Replacement: 2 단계, 이미지 2/2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: 3 단계, 이미지 1/1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: 4 단계, 이미지 1/1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lucas Pimentel
회원 가입일: 04/02/19
1,010 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 회원
UMASSD-JULIE-S19S5G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 23
전체 시간: 1,044
