주요 콘텐츠로 건너뛰기
소개
Follow these steps to disassemble the plastic casing of the RIDGID R84015 X2 power drill.
  1. Remove the backplate. Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. Remove the drill handle.
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. Remove the gear casing from the body. Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. With your drill taken apart, move your attention to the trigger and forward reverse switch.
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  6. Check to see that the forward reverse switch isn't broken.
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  7. With the battery attached, check that the wires work when the trigger is pulled.
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  8. Make sure plastic is not broken and switch is not stuck.
    • Make sure plastic is not broken and switch is not stuck.
  9. Looks good, doesn't it?
    • Looks good, doesn't it?
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 2010년 04월 12일
97 평판
안내서 1개 작성함
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 회원
CPSU-GARNER-S10S15G48
6 회원들
안내서 5개 작성하였습니다
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 39
전체 시간: 10,702
