주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
RIDGID R84015 X2 Disassembly
필요한 것
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 1/2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 2/2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: 2 단계, 이미지 1/1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: 3 단계, 이미지 1/2 RIDGID R84015 X2 Disassembly: 3 단계, 이미지 2/2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: 4 단계, 이미지 1/1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: 5 단계, 이미지 1/1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: 6 단계, 이미지 1/1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: 7 단계, 이미지 1/1
    • Make sure plastic is not broken and switch is not stuck.
  8. RIDGID R84015 X2 Disassembly: 8 단계, 이미지 1/1
    • Looks good, doesn't it?
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 04/12/10
97 평판
안내서 1개 작성함
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 회원
CPSU-GARNER-S10S15G48
6 회원들
안내서 10개 작성하였습니다
댓글 한 개
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 26
전체 시간: 13,545
