소개
Follow these steps to disassemble the drill and replace the planetary gear for the RIDGID R84015 X2 power drill.
부품
부품은 필요하지 않습니다.
  1. Remove the backplate. Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. Remove the drill handle.
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. Remove the gear casing from the body. Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Prepare to remove the gear chamber.
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  6. Remove the motor from the drill by gently pulling the motor away from the gear chamber. NOTE: Handle the gear chamber with caution as the gears are now loose.
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  7. Remove the plastic gear chamber.
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  8. Remove each component from the gear assembly. Replace components as needed. Reassemble the drill following the gear replacement instructions in reverse order.
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Evan Long
회원 가입일: 2010년 04월 15일
232 평판
안내서 4개 작성하였습니다
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 회원
CPSU-GARNER-S10S15G48
6 회원들
안내서 5개 작성하였습니다
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 5,518
