주요 콘텐츠로 건너뛰기
RIDGID R84015 X2 Planetary Gear Replacement Guide
필요한 것
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 2개 중 1개 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 2개 중 2개
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: 2 단계, 이미지 1개 중 1개
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: 3 단계, 이미지 2개 중 1개 RIDGID R84015 X2 Planetary Gear Replacement Guide: 3 단계, 이미지 2개 중 2개
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: 4 단계, 이미지 1개 중 1개
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: 5 단계, 이미지 2개 중 1개 RIDGID R84015 X2 Planetary Gear Replacement Guide: 5 단계, 이미지 2개 중 2개
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: 6 단계, 이미지 1개 중 1개
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: 7 단계, 이미지 2개 중 1개 RIDGID R84015 X2 Planetary Gear Replacement Guide: 7 단계, 이미지 2개 중 2개
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Evan Long
회원 가입일: 04/15/10
274 평판
안내서 4개를 작성함
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 회원
CPSU-GARNER-S10S15G48
6 회원들
안내서 10개를 작성함
1가이드 댓글
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 6,545
