주요 콘텐츠로 건너뛰기
RIDGID R84015 X2 Speed Switch Replacement
필요한 것
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 1/2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: 1 단계, 이미지 2/2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: 2 단계, 이미지 1/1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: 3 단계, 이미지 1/2 RIDGID R84015 X2 Speed Switch Replacement: 3 단계, 이미지 2/2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: 4 단계, 이미지 1/1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: 5 단계, 이미지 1/2 RIDGID R84015 X2 Speed Switch Replacement: 5 단계, 이미지 2/2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan Long
회원 가입일: 04/15/10
262 평판
안내서 4개 작성하였습니다
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 회원
CPSU-GARNER-S10S15G48
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 3,604
