주요 콘텐츠로 건너뛰기
RIDGID R860052 Motor Replacement
필요한 것
  1. RIDGID R860052 Motor Replacement, Motor: 1 단계, 이미지 1/2 RIDGID R860052 Motor Replacement, Motor: 1 단계, 이미지 2/2
    • Remove the battery from the drill before you begin.
    • Use a T10 Torx screwdriver to remove the ten screws on the information label side of the drill.
    • These ten screws are 19 mm long.
  2. RIDGID R860052 Motor Replacement: 2 단계, 이미지 1/1
    • Lift off and remove the cover with the informational label.
  3. RIDGID R860052 Motor Replacement: 3 단계, 이미지 1/3 RIDGID R860052 Motor Replacement: 3 단계, 이미지 2/3 RIDGID R860052 Motor Replacement: 3 단계, 이미지 3/3
    • Remove the switch assembly, chuck, and motor from all drill covers.
  4. RIDGID R860052 Motor Replacement: 4 단계, 이미지 1/2 RIDGID R860052 Motor Replacement: 4 단계, 이미지 2/2
    • Twist the chuck and motor in the opposite direction and gently pull them apart.
  5. RIDGID R860052 Motor Replacement: 5 단계, 이미지 1/3 RIDGID R860052 Motor Replacement: 5 단계, 이미지 2/3 RIDGID R860052 Motor Replacement: 5 단계, 이미지 3/3
    • Desolder the black and red wires from the motor.
    • Replace motor and resolder the black and red wires back onto the motor.
    • Be aware of the heat level of the metal part on the soldering tool.
결론
Andrea Hernandez
회원 가입일: 02/05/19
204 평판
안내서 1개 작성함
UC Davis, Team S18-G4, Lore Winter 2019 UC Davis, Team S18-G4, Lore Winter 2019 회원
UCD-LORE-W19S18G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 479
