소개
If the drill does not turn on after pressing the trigger or it does not stop turning even after you release the trigger, the switch assembly might be damaged. This guide will provide guidance to the process of replacing a broken switch assembly in a RIDGID R860052.
필요한 것
Use a T10 Torx screwdriver to unscrew the ten screws on the information label side of the drill.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
