주요 콘텐츠로 건너뛰기
RK5 PLUS VR Headset Headband Replacement
필요한 것
  1. RK5 PLUS VR Headset Headband Replacement, Headband: 1 단계, 이미지 3개 중 1개 RK5 PLUS VR Headset Headband Replacement, Headband: 1 단계, 이미지 3개 중 2개 RK5 PLUS VR Headset Headband Replacement, Headband: 1 단계, 이미지 3개 중 3개
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
  2. RK5 PLUS VR Headset Headband Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
  3. RK5 PLUS VR Headset Headband Replacement: 3 단계, 이미지 3개 중 1개 RK5 PLUS VR Headset Headband Replacement: 3 단계, 이미지 3개 중 2개 RK5 PLUS VR Headset Headband Replacement: 3 단계, 이미지 3개 중 3개
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
  4. RK5 PLUS VR Headset Headband Replacement: 4 단계, 이미지 3개 중 1개 RK5 PLUS VR Headset Headband Replacement: 4 단계, 이미지 3개 중 2개 RK5 PLUS VR Headset Headband Replacement: 4 단계, 이미지 3개 중 3개
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
  5. RK5 PLUS VR Headset Headband Replacement: 5 단계, 이미지 2개 중 1개 RK5 PLUS VR Headset Headband Replacement: 5 단계, 이미지 2개 중 2개
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
  6. RK5 PLUS VR Headset Headband Replacement: 6 단계, 이미지 3개 중 1개 RK5 PLUS VR Headset Headband Replacement: 6 단계, 이미지 3개 중 2개 RK5 PLUS VR Headset Headband Replacement: 6 단계, 이미지 3개 중 3개
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
  7. RK5 PLUS VR Headset Headband Replacement: 7 단계, 이미지 1개 중 1개
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
결론
작성자
3다른 기여자 명과 함께
Faraaz Abdul
회원 가입일: 01/30/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 403
