주요 콘텐츠로 건너뛰기
RYDIS H68 Pro Side Brush Motor Replacement
필요한 것
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: 1 단계, 이미지 1/2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: 2 단계, 이미지 1/1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 3 단계, 이미지 1/3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 3 단계, 이미지 2/3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: 3 단계, 이미지 3/3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: 4 단계, 이미지 1/3 RYDIS H68 Pro Side Brush Motor Replacement: 4 단계, 이미지 2/3 RYDIS H68 Pro Side Brush Motor Replacement: 4 단계, 이미지 3/3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: 5 단계, 이미지 1/3 RYDIS H68 Pro Side Brush Motor Replacement: 5 단계, 이미지 2/3 RYDIS H68 Pro Side Brush Motor Replacement: 5 단계, 이미지 3/3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: 6 단계, 이미지 1/1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: 7 단계, 이미지 1/1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: 8 단계, 이미지 1/1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: 9 단계, 이미지 1/1
    • The side brush motor can now be removed by lifting it up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jude auguste
회원 가입일: 02/15/17
108 평판
안내서 1개 작성함
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 회원
Repair Café
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 584
