주요 콘텐츠로 건너뛰기
RYOBI P422 Body Replacement
필요한 것
  1. RYOBI P422 Body Replacement, Battery and Handle: 1 단계, 이미지 1/2 RYOBI P422 Body Replacement, Battery and Handle: 1 단계, 이미지 2/2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: 2 단계, 이미지 1/1
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: 3 단계, 이미지 1/3 RYOBI P422 Body Replacement: 3 단계, 이미지 2/3 RYOBI P422 Body Replacement: 3 단계, 이미지 3/3
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: 4 단계, 이미지 1/2 RYOBI P422 Body Replacement: 4 단계, 이미지 2/2
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: 5 단계, 이미지 1/3 RYOBI P422 Body Replacement: 5 단계, 이미지 2/3 RYOBI P422 Body Replacement: 5 단계, 이미지 3/3
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: 6 단계, 이미지 1/2 RYOBI P422 Body Replacement: 6 단계, 이미지 2/2
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: 7 단계, 이미지 1/3 RYOBI P422 Body Replacement: 7 단계, 이미지 2/3 RYOBI P422 Body Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: 8 단계, 이미지 1/2 RYOBI P422 Body Replacement: 8 단계, 이미지 2/2
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Lamanuzzi
회원 가입일: 03/20/15
229 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-6, Duarte Spring 2015 UMass Dartmouth, Team 3-6, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 1,407
