주요 콘텐츠로 건너뛰기
Radica Lighted Poker Case Lid Spring Replacement
필요한 것
  1. Radica Lighted Poker Case Lid Spring Replacement, Case Lid Spring: 1 단계, 이미지 1/1
    • Turn over your Lighted Poker so the back is facing upwards.
  2. Radica Lighted Poker Case Lid Spring Replacement: 2 단계, 이미지 1/3 Radica Lighted Poker Case Lid Spring Replacement: 2 단계, 이미지 2/3 Radica Lighted Poker Case Lid Spring Replacement: 2 단계, 이미지 3/3
    • Remove the six silver 6 mm screws with a Phillips #1 screwdriver.
    • Do not unscrew the centerpiece. It is for the batteries.
  3. Radica Lighted Poker Case Lid Spring Replacement: 3 단계, 이미지 1/3 Radica Lighted Poker Case Lid Spring Replacement: 3 단계, 이미지 2/3 Radica Lighted Poker Case Lid Spring Replacement: 3 단계, 이미지 3/3
    • Open the device slowly without breaking or tearing the wires.
    • Remove the three black 7 mm self-sealing screws using a Phillips #00 screwdriver.
  4. Radica Lighted Poker Case Lid Spring Replacement: 4 단계, 이미지 1/3 Radica Lighted Poker Case Lid Spring Replacement: 4 단계, 이미지 2/3 Radica Lighted Poker Case Lid Spring Replacement: 4 단계, 이미지 3/3
    • Gently remove both the button and hook piece.
    • Remove the damaged or old spring with a new 10 mm long and 8 mm to 3 mm radius spring.
    • Apply a small portion of grease lubricant on the button and hook piece to run smoother.
결론
Diego Valdez
회원 가입일: 05/02/23
159 평판
안내서 1개 작성함
CSU Los Angeles, Team 2-19, Briggs Spring 2023 CSU Los Angeles, Team 2-19, Briggs Spring 2023 회원
CSULA-BRIGGS-S23S2G19
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 64
