주요 콘텐츠로 건너뛰기
Raidmax Alpha Case Graphics Card Replacement
필요한 것
  1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 1 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 1 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 1 단계, 이미지 3/3
    • Turn off the computer and the power supply to the computer.
  2. Raidmax Alpha Case Graphics Card Replacement: 2 단계, 이미지 1/2 Raidmax Alpha Case Graphics Card Replacement: 2 단계, 이미지 2/2
    • Recycle the power in the computer by pressing the power button on and off again. This removes any remaining current to the computer.
  3. Raidmax Alpha Case Graphics Card Replacement: 3 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 3 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 3 단계, 이미지 3/3
    • Access the glass side panel by turning the back of the case to the left when looking at it from the front.
  4. Raidmax Alpha Case Graphics Card Replacement: 4 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 4 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 4 단계, 이미지 3/3
    • Remove the two screws on the glass side panel. These are thumb screws so they can simply be removed by twisting them to the left.
  5. Raidmax Alpha Case Graphics Card Replacement: 5 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 5 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 5 단계, 이미지 3/3
    • Carefully slide the glass panel to the left and then pull it off to remove it.
  6. Raidmax Alpha Case Graphics Card Replacement: 6 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 6 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 6 단계, 이미지 3/3
    • Tilt the case backward and lay it on its backside. This is done so the card will not pull down when being removed.
  7. Raidmax Alpha Case Graphics Card Replacement: 7 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 7 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 7 단계, 이미지 3/3
    • Undo the power connection to the card. Push the clip on the connector and pull the cable up.
  8. Raidmax Alpha Case Graphics Card Replacement: 8 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 8 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 8 단계, 이미지 3/3
    • Remove three 6.3 mm screws to the card located on the left side of the case using a Phillips #2 screwdriver.
  9. Raidmax Alpha Case Graphics Card Replacement: 9 단계, 이미지 1/2 Raidmax Alpha Case Graphics Card Replacement: 9 단계, 이미지 2/2
    • Push down the clip to the motherboard circled in red.
  10. Raidmax Alpha Case Graphics Card Replacement: 10 단계, 이미지 1/3 Raidmax Alpha Case Graphics Card Replacement: 10 단계, 이미지 2/3 Raidmax Alpha Case Graphics Card Replacement: 10 단계, 이미지 3/3
    • Carefully grip the old graphics card with two hands and lift it out of the case.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Julia Strecker
회원 가입일: 03/19/21
349 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 54
전체 시간: 3,161
