주요 콘텐츠로 건너뛰기
Rain-X Chipped Windshield Repair
필요한 것
  1. Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: 1 단계, 이미지 1/3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: 1 단계, 이미지 2/3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: 1 단계, 이미지 3/3
    • To remove excess glass, scrape over the surface of the chip with the included razor blade.
  2. Rain-X Chipped Windshield Repair: 2 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 2 단계, 이미지 2/2
    • Attach the Rain-X applicator base to the windshield, with the center of the base directly above the chip.
  3. Rain-X Chipped Windshield Repair: 3 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 3 단계, 이미지 2/2
    • Cut the tip of the repair resin bottle using the razor blade.
  4. Rain-X Chipped Windshield Repair: 4 단계, 이미지 1/3 Rain-X Chipped Windshield Repair: 4 단계, 이미지 2/3 Rain-X Chipped Windshield Repair: 4 단계, 이미지 3/3
    • To attach resin chamber, screw the chamber into the center ring of the applicator base.
  5. Rain-X Chipped Windshield Repair: 5 단계, 이미지 1/1
    • Screw the resin chamber clockwise until it is in contact with the windshield.
  6. Rain-X Chipped Windshield Repair: 6 단계, 이미지 1/3 Rain-X Chipped Windshield Repair: 6 단계, 이미지 2/3 Rain-X Chipped Windshield Repair: 6 단계, 이미지 3/3
    • Apply 3-6 drops of resin from the resin repair bottle into the resin chamber.
  7. Rain-X Chipped Windshield Repair: 7 단계, 이미지 1/3 Rain-X Chipped Windshield Repair: 7 단계, 이미지 2/3 Rain-X Chipped Windshield Repair: 7 단계, 이미지 3/3
    • To add the pressure driver, screw the driver clockwise into the resin chamber.
    • Make sure to tighten almost all the way.
    • Make sure the pressure driver is in contact with the windshield.
  8. Rain-X Chipped Windshield Repair: 8 단계, 이미지 1/1
    • Set timer for 4-6 minutes - Let the adhesive absorb into the chip for 4-6 minutes.
    • To determine if the repair resin has absorbed properly, look at the glass from a 45 degree angle.
    • After the 4-6 minutes end, unscrew the pressure driver, turning it counter clockwise. Remove it to release any trapped air.
  9. Rain-X Chipped Windshield Repair: 9 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 9 단계, 이미지 2/2
    • Reinsert pressure driver by twisting clockwise.
    • This will discard any air remaining in the chip.
  10. Rain-X Chipped Windshield Repair: 10 단계, 이미지 1/1
    • To check for remaining damage, look for a dark color to appear.
  11. Rain-X Chipped Windshield Repair: 11 단계, 이미지 1/1
    • Leave to cure for 5-10 minutes.
  12. Rain-X Chipped Windshield Repair: 12 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 12 단계, 이미지 2/2
    • Once finished curing, remove the resin chamber and the pressure driver by screwing counter clockwise.
  13. Rain-X Chipped Windshield Repair: 13 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 13 단계, 이미지 2/2
    • Remove the applicator by using the tabs on the suction cups.
  14. Rain-X Chipped Windshield Repair: 14 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 14 단계, 이미지 2/2
    • Clean off any excess adhesive from the windshield.
  15. Rain-X Chipped Windshield Repair: 15 단계, 이미지 1/2 Rain-X Chipped Windshield Repair: 15 단계, 이미지 2/2
    • Cover the chip gently with a curing strip.
  16. Rain-X Chipped Windshield Repair: 16 단계, 이미지 1/1
    • Move the car into direct sunlight and leave for 4-6 hours.
    • Remove the curing strip and enjoy.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey Ritchie
회원 가입일: 10/26/18
286 평판
안내서 1개 작성함
UC Davis, Team S1-G8, Bender Fall 2018 UC Davis, Team S1-G8, Bender Fall 2018 회원
UCD-BENDER-F18S1G8
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
If you do not have a sunny day, what is the best UV wavelength in nm, watts, and length of time to fully cure the resin.
Thanks much!
AZRic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 25
30일 전: 78
전체 시간: 4,703
