주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Raleigh M20 Chain Guard Replacement
필요한 것
  1. Raleigh M20 Chain Guard Replacement, Raleigh M20 Pedal Removal: 1 단계, 이미지 1개 중 1개
    • Use an 8" adjustable crescent wrench to fit it into the base of the pedal.
  2. Raleigh M20 Chain Guard Replacement: 2 단계, 이미지 2개 중 1개 Raleigh M20 Chain Guard Replacement: 2 단계, 이미지 2개 중 2개
    • Twist the the wrench in a counter -clockwise direction to unscrew the right-side pedal (The chain side).
    • Repeat the process on the other side with a clockwise direction.
  3. Raleigh M20 Chain Guard Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the wrench continuously until the pedal detaches from the crank arm.
  4. Raleigh M20 Chain Guard Replacement, Chain Guard: 4 단계, 이미지 2개 중 1개 Raleigh M20 Chain Guard Replacement, Chain Guard: 4 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to remove the dust cap of the crank arm.
    • Repeat the process on other side.
  5. Raleigh M20 Chain Guard Replacement: 5 단계, 이미지 2개 중 1개 Raleigh M20 Chain Guard Replacement: 5 단계, 이미지 2개 중 2개
    • Next, use a socket wrench to unscrew the crank arm.
    • Turn the socket wrench clockwise to remove the bolt.
  6. Raleigh M20 Chain Guard Replacement: 6 단계, 이미지 3개 중 1개 Raleigh M20 Chain Guard Replacement: 6 단계, 이미지 3개 중 2개 Raleigh M20 Chain Guard Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the crank arm puller into the screw hole.
    • Now use a crescent wrench to tighten the crank arm puller. Twist it in a clockwise direction until the puller is fully tightened.
    • Do not over-tighten the crank arm puller. Stop once it's fully tightened.
  7. Raleigh M20 Chain Guard Replacement: 7 단계, 이미지 3개 중 1개 Raleigh M20 Chain Guard Replacement: 7 단계, 이미지 3개 중 2개 Raleigh M20 Chain Guard Replacement: 7 단계, 이미지 3개 중 3개
    • Turn the crank arm puller in a clockwise direction to remove it.
    • There will be some resistance when removing the crank arm.
    • Repeat step 2 to 4 on the other side.
  8. Raleigh M20 Chain Guard Replacement: 8 단계, 이미지 2개 중 1개 Raleigh M20 Chain Guard Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the crank arm over with the chainring on it.
    • Locate the four screws on the back of the chainring.
  9. Raleigh M20 Chain Guard Replacement: 9 단계, 이미지 3개 중 1개 Raleigh M20 Chain Guard Replacement: 9 단계, 이미지 3개 중 2개 Raleigh M20 Chain Guard Replacement: 9 단계, 이미지 3개 중 3개
    • Use a Phillips #2 screwdriver to remove the four screws on the back of the chainring.
  10. Raleigh M20 Chain Guard Replacement: 10 단계, 이미지 1개 중 1개
    • Flip the chain guard over.
  11. Raleigh M20 Chain Guard Replacement: 11 단계, 이미지 2개 중 1개 Raleigh M20 Chain Guard Replacement: 11 단계, 이미지 2개 중 2개
    • Hold on to the crank arm and pull out the chain guard gently.
결론
If you are replacing the chain guard, use the new chain guard when reassembling the device.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Carl Lind
회원 가입일: 09/26/12
55 평판
안내서 1개를 작성함
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 회원
CPSU-FORTE-F12S7G49
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 40
전체 시간: 4,232
