소개
Follow this guide to learn how to replace the chain guard. Before removing the crank arms, the pedals must first be removed . To reassemble the crank arms and chain guard, follow steps in reverse order.
Use an 8" adjustable crescent wrench to fit it into the base of the pedal.
Use a flathead screwdriver to remove the dust cap of the crank arm.
Repeat the process on other side.
거의 끝나갑니다!
If you are replacing the chain guard, use the new chain guard when reassembling the device.
결론
