주요 콘텐츠로 건너뛰기
Raleigh M20 Handlebars Replacement
필요한 것
  1. Raleigh M20 Handlebars Replacement, Handlebars: 1 단계, 이미지 2개 중 1개 Raleigh M20 Handlebars Replacement, Handlebars: 1 단계, 이미지 2개 중 2개
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: 2 단계, 이미지 3개 중 1개 Raleigh M20 Handlebars Replacement: 2 단계, 이미지 3개 중 2개 Raleigh M20 Handlebars Replacement: 2 단계, 이미지 3개 중 3개
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: 3 단계, 이미지 2개 중 1개 Raleigh M20 Handlebars Replacement: 3 단계, 이미지 2개 중 2개
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: 4 단계, 이미지 3개 중 1개 Raleigh M20 Handlebars Replacement: 4 단계, 이미지 3개 중 2개 Raleigh M20 Handlebars Replacement: 4 단계, 이미지 3개 중 3개
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
결론
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
작성자
5다른 기여자 명과 함께
Jon Ribera
회원 가입일: 09/26/12
72 평판
안내서 1개를 작성함
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 회원
CPSU-FORTE-F12S7G49
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 2,203
