주요 콘텐츠로 건너뛰기
Rapoo N1600 Cable Replacement
필요한 것
  1. Rapoo N1600 Cable Replacement, Cable: 1 단계, 이미지 1개 중 1개
    • Start by turning the mouse over where the bottom is facing up.
  2. Rapoo N1600 Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screw located in the hole.
  3. Rapoo N1600 Cable Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the mouse over and detach the middle mouse part.
    • Keep the mouse on a flat surface.
  4. Rapoo N1600 Cable Replacement: 4 단계, 이미지 3개 중 1개 Rapoo N1600 Cable Replacement: 4 단계, 이미지 3개 중 2개 Rapoo N1600 Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to lift the cable connector plug slowly.
    • Use gentle pressure as pulling with force may damage the scroll wheel connector.
    • Using two fingers, slowly wiggle the connector plug out.
    • Do not pull from the wires.
  5. Rapoo N1600 Cable Replacement: 5 단계, 이미지 2개 중 1개 Rapoo N1600 Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Place your index finger under the motherboard and lift your index finger so the motherboard pops up.
    • Ensure the bottom of the motherboard is held flat in your hand so the pieces don't fall out.
  6. Rapoo N1600 Cable Replacement: 6 단계, 이미지 2개 중 1개 Rapoo N1600 Cable Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the old mouse cable.
    • Place the matching cross from the new mouse cable on the cross outline.
    • Keep the cable away from the scroll wheel area. Make sure the cable stays to the side.
    • Make sure the mouse sensor stays in place. If it falls out, set it back in place.
  7. Rapoo N1600 Cable Replacement: 7 단계, 이미지 3개 중 1개 Rapoo N1600 Cable Replacement: 7 단계, 이미지 3개 중 2개 Rapoo N1600 Cable Replacement: 7 단계, 이미지 3개 중 3개
    • To replace the motherboard, match the circle from the motherboard and mouse and press down.
    • It will make a clicking sound.
    • Add the mouse cable plug to the socket. Press down so it connects.
  8. Rapoo N1600 Cable Replacement: 8 단계, 이미지 2개 중 1개 Rapoo N1600 Cable Replacement: 8 단계, 이미지 2개 중 2개
    • Slide an iFixit opening pick between the top shell and middle slowly until the end. Do this for the other side as well.
  9. Rapoo N1600 Cable Replacement: 9 단계, 이미지 3개 중 1개 Rapoo N1600 Cable Replacement: 9 단계, 이미지 3개 중 2개 Rapoo N1600 Cable Replacement: 9 단계, 이미지 3개 중 3개
    • Match the middle part of the mouse with the bottom and slide it from top to bottom.
    • Once the middle part is attached, add the top shell of the mouse. Follow the pattern of the holes as they will help you.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Johan Salceda-Arredondo
회원 가입일: 08/22/22
193 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-25, Briggs Fall 2022 CSU Los Angeles, Team 2-25, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S2G25
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 53
전체 시간: 879
