주요 콘텐츠로 건너뛰기
Ray Ban Eyeglasses Lens Replacement
필요한 것
  1. Ray Ban Eyeglasses Lens Replacement, Lens: 1 단계, 이미지 1/1
    • Source a pair of lenses that will fit the frames of your current glasses.
  2. Ray Ban Eyeglasses Lens Replacement: 2 단계, 이미지 1/1
    • Grip the top and bottom of the frame with both hands.
    • Do this very firmly, you dontt want to break the frame.
  3. Ray Ban Eyeglasses Lens Replacement: 3 단계, 이미지 1/1
    • Gently pull up on the top of the frame while pushing the lens out from the back.
    • When pushing back try to wiggle the lens first.
    • Be sure not to exert too much pressure on the frame or it may bend or break.
  4. Ray Ban Eyeglasses Lens Replacement: 4 단계, 이미지 1/1
    • Wipe the replacement lens clean with a damp cloth or towel.
  5. Ray Ban Eyeglasses Lens Replacement: 5 단계, 이미지 1/1
    • Insert the replacement lens starting at the nose bridge.
    • Line up the lens with the frame.
  6. Ray Ban Eyeglasses Lens Replacement: 6 단계, 이미지 1/1
    • Press the replacement lens along the perimeter until it snaps securely into place.
    • Once it's in place, nudge it around to be sure.
  7. Ray Ban Eyeglasses Lens Replacement: 7 단계, 이미지 1/1
    • Gently apply heat to the perimeter of the lens for a short period of time with a hairdryer on low.
    • Only do this for a couple of seconds as you don't want to burn or melt the frame or lens.
  8. Ray Ban Eyeglasses Lens Replacement: 8 단계, 이미지 1/1
    • You’ve got new glasses!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Abdullah Syed
회원 가입일: 09/15/21
225 평판
안내서 1개 작성함
York University, Team F-1, Woodhouse Fall 2021 York University, Team F-1, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG1
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 121
전체 시간: 1,945
