주요 콘텐츠로 건너뛰기
Razer Barracuda X Motherboard Replacement
필요한 것
  1. Razer Barracuda X Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Razer Barracuda X Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the cushion by pulling it off from the edge and out from the grooves, Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Motherboard Replacement: 2 단계, 이미지 1/3 Razer Barracuda X Motherboard Replacement: 2 단계, 이미지 2/3 Razer Barracuda X Motherboard Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver to unscrew the four screws that attach the two pieces of the right speaker together.
    • Gently lift the plastic plate away from the housing, with care not to damage the connected wire.
  3. Razer Barracuda X Motherboard Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the single screw attaching the volume spinner to the motherboard.
    • Remove the spinner.
  4. Razer Barracuda X Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the Phillips #0 screws securing the I/O board from the bottom shell of the right speaker.
  5. Razer Barracuda X Motherboard Replacement: 5 단계, 이미지 1/2 Razer Barracuda X Motherboard Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • To fully remove the I/O board from the right speaker, use tweezers to unplug the ribbon cable attaching the I/O board to the main motherboard.
  6. Razer Barracuda X Motherboard Replacement: 6 단계, 이미지 1/1
    • Using the same Philips #0 screwdriver, remove the four screws attaching the motherboard to the plastic housing. Once those screws are removed, remove the main motherboard and replace it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josiah Cassidy
회원 가입일: 10/26/22
241 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-3, Petersen Fall 2022 UMass Dartmouth, Team 2-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G3
4 회원들
안내서 7개 작성하였습니다
댓글 3개
Now if I could just find somewhere to buy the I/O board. My volume slider is crackling and sometimes one cup is louder than the other.
Michael Nugent - 답글
You ever find a replacement?
Gaelan Garrett -
@michaelnugent My volume wheel just broke too! Must be a weak point in the design.
Michael Shu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 61
30일 전: 211
전체 시간: 3,102
