주요 콘텐츠로 건너뛰기
Razer Basilisk V3 Backplate Replacement
필요한 것
  1. Razer Basilisk V3 Backplate Replacement, Skates: 1 단계, 이미지 1개 중 1개
    • Locate each of the skates.
  2. Razer Basilisk V3 Backplate Replacement: 2 단계, 이미지 3개 중 1개 Razer Basilisk V3 Backplate Replacement: 2 단계, 이미지 3개 중 2개 Razer Basilisk V3 Backplate Replacement: 2 단계, 이미지 3개 중 3개
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Backplate Replacement, Backplate: 3 단계, 이미지 1개 중 1개
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Backplate Replacement: 4 단계, 이미지 3개 중 1개 Razer Basilisk V3 Backplate Replacement: 4 단계, 이미지 3개 중 2개 Razer Basilisk V3 Backplate Replacement: 4 단계, 이미지 3개 중 3개
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Backplate Replacement: 5 단계, 이미지 3개 중 1개 Razer Basilisk V3 Backplate Replacement: 5 단계, 이미지 3개 중 2개 Razer Basilisk V3 Backplate Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
결론
작성자
3다른 기여자 명과 함께
Brendin Costa
회원 가입일: 03/18/24
402 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024 회원
UMASSD-SANTIN-S24S1G2
3 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 46
지난 30일: 219
전체 시간: 1,040
