주요 콘텐츠로 건너뛰기
Razer Basilisk V3 Programmable Buttons Replacement
필요한 것
  1. Razer Basilisk V3 Programmable Buttons Replacement, Skates: 1 단계, 이미지 1개 중 1개
    • Locate the highlighted white skates on the bottom of the mouse.
  2. Razer Basilisk V3 Programmable Buttons Replacement: 2 단계, 이미지 3개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement: 2 단계, 이미지 3개 중 2개 Razer Basilisk V3 Programmable Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Programmable Buttons Replacement, Backplate: 3 단계, 이미지 1개 중 1개
    • Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Programmable Buttons Replacement: 4 단계, 이미지 3개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement: 4 단계, 이미지 3개 중 2개 Razer Basilisk V3 Programmable Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Programmable Buttons Replacement: 5 단계, 이미지 3개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement: 5 단계, 이미지 3개 중 2개 Razer Basilisk V3 Programmable Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: 6 단계, 이미지 3개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: 6 단계, 이미지 3개 중 2개 Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: 6 단계, 이미지 3개 중 3개
    • Locate the mini module near the top portion of the mouse.
    • Use a JIS #0 screwdriver to remove the screws securing the module. Two screws measure 4 mm and the remaining two screws measue 10mm.
    • Carefully lift and remove the module from the mouse chassis.
  7. Razer Basilisk V3 Programmable Buttons Replacement: 7 단계, 이미지 2개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Identify SW2, SW3, and SW4 which are marked on the removed mini module.
    • Use a desoldering pump or solder wick to remove the solder from the contacts of SW14 and SW15.
    • Carefully remove the old buttons using tweezers.
    • Position the new click mechanisms for SW14 and SW15 and secure them by resoldering to the contacts.
  8. Razer Basilisk V3 Programmable Buttons Replacement: 8 단계, 이미지 3개 중 1개 Razer Basilisk V3 Programmable Buttons Replacement: 8 단계, 이미지 3개 중 2개 Razer Basilisk V3 Programmable Buttons Replacement: 8 단계, 이미지 3개 중 3개
    • Identify SW11 and SW12 which are marked on the removed mini module.
    • Remove the mini module plastic backing piece to allow for the removal of solder.
    • Always work in a well-ventilated area when handling solder to avoid inhaling fumes.
    • Desolder and remove the old through-hole buttons using similar techniques.
    • Insert the new buttons for SW11 and SW12, ensuring they are properly aligned.
    • Resolder the connections to secure the new buttons in place.
결론
Reassemble the mouse by reversing the disassembly process. Ensure all components are securely fastened and the mini module is correctly positioned. Test the functionality of the newly installed buttons to confirm that they are responsive and operating as intended.
작성자
2다른 기여자 명과 함께
Brendin Costa
회원 가입일: 03/18/24
402 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024 회원
UMASSD-SANTIN-S24S1G2
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 70
전체 시간: 863
