주요 콘텐츠로 건너뛰기
Razer BlackWidow Chroma Back Panel Replacement
필요한 것
  1. Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: 1 단계, 이미지 1/2 Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: 1 단계, 이미지 2/2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer BlackWidow Chroma Back Panel Replacement, Front Panel: 2 단계, 이미지 1/2 Razer BlackWidow Chroma Back Panel Replacement, Front Panel: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer BlackWidow Chroma Back Panel Replacement, Back Panel: 3 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove all ten screws found along the outer edges of the keyboard.
  4. Razer BlackWidow Chroma Back Panel Replacement: 4 단계, 이미지 1/1
    • Insert the Jimmy along the edges of the back panel and remove the back panel from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Lacks details on where the clips are. It resulted in prying an area where there was one and it broke. We need updated images with those details. If I can I will do do when I reassemble.
Kellic Normand - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 93
전체 시간: 4,484
