주요 콘텐츠로 건너뛰기
Razer BlackWidow Chroma Key Replacement
필요한 것
  1. Razer BlackWidow Chroma Key Replacement, Key: 1 단계, 이미지 1/1
    • If the problematic key is still attached, place the edge of the medium blue pry tool under the key. Then gently pry up until key is detached.
  2. Razer BlackWidow Chroma Key Replacement: 2 단계, 이미지 1/1
    • Some larger keys may also be held in by two small metal hooks. To separate them gently slide the key left to separate right hook, then to the right to separate the left hook. Be careful not to break the mounting holes on the key itself.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kirk Foreman
회원 가입일: 02/01/17
248 평판
안내서 1개 작성함
UW Tacoma, Team 2-6, Rose Winter 2017 UW Tacoma, Team 2-6, Rose Winter 2017 회원
UWT-ROSE-W17S2G6
3 회원들
안내서 3개 작성하였습니다
댓글 3개
This has absolutely nothing to do with fixing a stuck key. Useless information.
Kyle - 답글
99% of steps to replace a key is missing. What a joke.
Jacinto - 답글
please change the name to “keycap” I don’t see this as useless but, misleading.
Shaun Conklin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 28
30일 전: 70
전체 시간: 12,675
