소개
In this replacement guide we will go over how to disassemble the Razer BlackWidow Chroma. After disassembling the keyboard there will be a link on how to solder and replace the lights.
필요한 것
Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
High brightness led’s, 3mm.
