주요 콘텐츠로 건너뛰기
Razer BlackWidow Chroma Lights Replacement
필요한 것
  1. Razer BlackWidow Chroma Lights Replacement, Lights: 1 단계, 이미지 1/1
    • Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
  2. Razer BlackWidow Chroma Lights Replacement: 2 단계, 이미지 1/1
    • Using a metal spudger, gently remove the plastic tabs that are covering the two screws.
  3. Razer BlackWidow Chroma Lights Replacement: 3 단계, 이미지 1/1
    • There are six 10mm screws indicated by the red markups . Remove the screws using the Phillips #0 Screwdriver.
  4. Razer BlackWidow Chroma Lights Replacement: 4 단계, 이미지 1/2 Razer BlackWidow Chroma Lights Replacement: 4 단계, 이미지 2/2
    • Using a metal spudger, begin prying off the faceplate of the keyboard. There are small tabs along the edge of the keyboard and the faceplate that must be released. There are four tabs along the front of the keyboard and two along each side.
  5. Razer BlackWidow Chroma Lights Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, lift the plastic covering away from the LED light.
  6. Razer BlackWidow Chroma Lights Replacement: 6 단계, 이미지 1/2 Razer BlackWidow Chroma Lights Replacement: 6 단계, 이미지 2/2
    • Using the Phillips #0 Screwdriver, remove the ten 10mm screws that are indicated by the red markers.
    • Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brooke Stevenson
회원 가입일: 02/01/17
182 평판
안내서 1개 작성함
UW Tacoma, Team 2-6, Rose Winter 2017 UW Tacoma, Team 2-6, Rose Winter 2017 회원
UWT-ROSE-W17S2G6
3 회원들
안내서 3개 작성하였습니다
댓글 2개
Anyone know what type of LEDs are need for the replacement?
Huayu Nie - 답글
High brightness led’s, 3mm.
Carlos Eduardo Pereira Reis -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 21
30일 전: 61
전체 시간: 17,524
