주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer BlackWidow Chroma Wire Harness Replacement
필요한 것
    1. Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: 1 단계, 이미지 2개 중 1개 Razer BlackWidow Chroma Wire Harness Replacement, Rubber Feet: 1 단계, 이미지 2개 중 2개
      • Turn the keyboard over so that it is lying flat on its face.
      • Use the iFixit opening tool to pry the rubber feet off the keyboard.
      댓글 쓰기
    1. Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: 2 단계, 이미지 2개 중 1개 Razer BlackWidow Chroma Wire Harness Replacement, Front Panel: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
      • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
      • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
      • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
      • Flip the keyboard over so the keys are facing up.
      • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
      댓글 쓰기
    1. Razer BlackWidow Chroma Wire Harness Replacement, Wire Harness: 3 단계, 이미지 1개 중 1개
      • Using a Philips #1 screwdriver, remove all ten screws found on the edges of the keyboard.
      • Two of the screws are found on either side of the main cable.
      댓글 쓰기
    2. Razer BlackWidow Chroma Wire Harness Replacement: 4 단계, 이미지 2개 중 1개 Razer BlackWidow Chroma Wire Harness Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the wire harness.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 36
전체 시간: 2,484
