주요 콘텐츠로 건너뛰기
Razer BlackWidow V4 Keycap Replacement
필요한 것
  1. Razer BlackWidow V4 Keycap Replacement, Keycap: 1 단계, 이미지 1/1
    • With key cap tweezers, align and grasp the edges of the keycap with force.
    • Once you have a firm grasp, push in and up.
  2. Razer BlackWidow V4 Keycap Replacement: 2 단계, 이미지 1/1
    • After the keycap is off the keyboard from the center holder, simply pull up and place to the side.
    • Make sure to remember the orientation in which the keyboard was facing.
  3. Razer BlackWidow V4 Keycap Replacement: 3 단계, 이미지 1/1
    • Use a spudger to realign the clip on the keyboard by simply pushing down on the side or center of the clip.
    • Make sure the clip is tucked in the center and both ends of the clip are parallel to each other making sure there is a keyboard wall inside the clip.
  4. Razer BlackWidow V4 Keycap Replacement: 4 단계, 이미지 1/1
    • Use either a dust cleaner or Co2 compressor to spray away any debris that may be inside the holder.
    • Make sure the clip does not fly away.
  5. Razer BlackWidow V4 Keycap Replacement: 5 단계, 이미지 1/1
    • With a caliper, measure the diameter of the fitment on the keyboard.
    • The measurements can either be of the side wall or center clip.
    • You can also use a ruler for this step.
  6. Razer BlackWidow V4 Keycap Replacement: 6 단계, 이미지 1/1
    • Measure the diameter of fitment on the keycap.
    • They should be the same or off by .02+/- .
    • If the fitment is bigger or smaller than .02+/- do not try and force it in. This will cause keyboard issues.
  7. Razer BlackWidow V4 Keycap Replacement: 7 단계, 이미지 1/1
    • Add a drop of keyboard cap lubricant to make sure that any friction or shear pressure is dispersed evenly throughout the lifespan of the keycap.
  8. Razer BlackWidow V4 Keycap Replacement: 8 단계, 이미지 1/1
    • Identify the orientation of which the keycap has to enter by noticing the clip holder on the keycap and the keyboard.
    • If the keyboard cap is OEM from Razer you do not need to worry about this step. The keycap contains a safety spacer that will not allow you to place it out of orientation.
  9. Razer BlackWidow V4 Keycap Replacement: 9 단계, 이미지 1/1
    • With a slight force press down and hold.
    • Once the keyboard has been clicked in successfully, enjoy your keyboard.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Hemi_perez2000
회원 가입일: 02/21/24
173 평판
안내서 1개 작성함
CSU Sacramento, Team 1-4, Laflen Spring 2024 CSU Sacramento, Team 1-4, Laflen Spring 2024 회원
CSUSAC-LAFLEN-S24S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 42
전체 시간: 85
