주요 콘텐츠로 건너뛰기
Razer Blade 14" (2013) Battery Replacement
필요한 것
  1. Razer Blade 14" (2013) Battery Replacement, Remove the back cover: 1 단계, 이미지 1/2 Razer Blade 14" (2013) Battery Replacement, Remove the back cover: 1 단계, 이미지 2/2
    • Remove all 10 Torx T5 Screws
  2. Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 2 단계, 이미지 1/3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 2 단계, 이미지 2/3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: 2 단계, 이미지 3/3
    • Flip the hold down up
    • Remove the cable
    • Repeat for second cable
  3. Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 3 단계, 이미지 1/3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 3 단계, 이미지 2/3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: 3 단계, 이미지 3/3
    • Unclip hold-down
    • Remove cable
  4. Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 4 단계, 이미지 1/3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 4 단계, 이미지 2/3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: 4 단계, 이미지 3/3
    • Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
    • Bend the connector backwards to prevent it from getting in the way of the motherboard.
  5. Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: 5 단계, 이미지 1/2 Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: 5 단계, 이미지 2/2
    • Remove the 7 battery screws
  6. Razer Blade 14" (2013) Battery Replacement, Remove the Battery: 6 단계, 이미지 1/2 Razer Blade 14" (2013) Battery Replacement, Remove the Battery: 6 단계, 이미지 2/2
    • Remove the battery by pulling up from the side closest to the motherboard
    • Be careful of the other cables and the battery cable
    • You will have to lift up just a bit, then slide forward to clear one cable and the back cover screws
결론
다른 21명이 해당 안내서를 완성하였습니다.
tallme15
회원 가입일: 03/09/13
902 평판
안내서 2개 작성하였습니다
댓글 17개
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
dinhphucloctmx - 답글
It seems that the only way to get the battery replaced is to send the laptop to Razer directly. According to others it costs about $200 plus shipping and so on. Unless you find something on eBay or that sort of thing.
tallme15 -
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
ceci - 답글
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
Samer Sultan -
Thank you for these instructions, it was very helpful, the only problem is now that the new battery has been installed, it will only charge to 73% and while its still plugged in the battery will drain down to 0%, is there a fix for this problem?
Jay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 28,114
